Starting out.
Old Feb 27, 2002 | 09:02 AM
BP89IROC's Avatar
Starting out.
Ok i see a lot of stuff about using a laptop to log data. I'm just wondering if there is an advantage to this or is it just cost? I remember seeing something about using excel to create a table that was used with one of the editing programs? Am i right here, any clarification would be much appreciated! Thanks.
Old Feb 27, 2002 | 10:39 AM
kevinc's Avatar
Car: 1982 Z28
Try tuning with a handheld scantool that only shows realtime snapshots, or saves 30sec of data that you have to scroll thru one frame at a time.
After this, the benefit of laptop data capture becomes more clear. You can dump the entire capture session into a spreadsheet and walk thru it easily. If you have enough disk space, you can save quite a bit...I captured 8MB worth of my morning commute when I was tuning my VE tables (speed density application) and got to see the engine in a variety of RPM/KPa conditions and vehicle speeds.
Old Feb 27, 2002 | 03:06 PM
BP89IROC's Avatar
I have a handheld scanner that i am using now. I guess i see what you are saying. It will just be easier because you will be able to have more data and an easier way to look at it?
Old Feb 27, 2002 | 05:33 PM
kevinc's Avatar
Car: 1982 Z28
Yeah, that and you'll have your engine data handy when you're burning chips...unless you want to wheel your PC out to the garage/driveway so you can look at your scantool display.
jklein337
Sep 19, 2018 06:23 PM
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wylecoyote08
Nov 6, 2015 03:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
