How do I print my BIN files?
Old Mar 14, 2002 | 09:32 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Is there a way to print my BIN files? GME Pro has the good old "F7" key to print tables, but I can't make it work. I'd like to print out some bins so I can compare them side by side. Going back and forth from one to the other makes it fairly impossible to get a good idea of the overall changes. Thanks.
Old Mar 14, 2002 | 10:51 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
There is a freeware tool called 'hexedit' that can do it. I can't remember where I found it though. It might be easier for you to use the MS-DOS "fc" command. I use it all the time. It does a binary compare between two files. For example:
File_A
01 10
File_B
AF BC
If you typed "fc File_A File_B > out.txt" at the MS-DOS command prompt. You would get a file called 'out.txt' that looks like:
comparing file: File_A with File_B
01 AF
10 BC
Give it a try. It does the mind boggling compare for you and only reports the differences.
Cheers,
J
Old Mar 15, 2002 | 12:13 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I use Winhex. The demo version will still print files.
You can look it up on download.com
Old Mar 15, 2002 | 06:52 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I really like "Binary Compare" from TunerCat for comparing ALL DIFFERENCES between various BINS. It's free for 30 days.
And yes, sometimes there are differences not only in the tables but inside the instructions themselves.
InfernalVortex
Apr 20, 2021 11:31 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
James Sutton
Sep 23, 2015 02:18 PM
