will winaldl work with comp. control carb
Old Mar 16, 2002 | 03:20 PM
CamaroFreak85's Avatar
Car: 1985 Camaro
Engine: 5.7, Vortec heads, Headers, TBI
Transmission: Built 700R4
Axle/Gears: 3.23 BW 9-Bolt Disc Brake
I noticed that winaldl has an ecu that is stated as clcc for 84-86 carb. Is this the computer controled carbs. found on the earlyer cars? When i went to hook my cable up to the aldl port there wasn't a pin in the data port, port E i think. Any one have any info on this?
Old Mar 17, 2002 | 07:34 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Use pin 'D' instead on carbed ECM's
Old Mar 17, 2002 | 02:05 PM
Car: 1985 Camaro
it still doesnt work with pin D and they cable is fine because it worked on a GMC Sonoma so i dont know whats wrong if you have any theorys or answers please help.
Old Mar 17, 2002 | 02:41 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
You might have to change the port settings too.
Select the raw data tab then open the configuration dialog.
Try changing the baudrate and watch the raw data tab if it starts reading data.
You might need a 10k resistor between the A and B terminals on the ALDL connector too.
Old Mar 17, 2002 | 02:57 PM
Car: 1985 Camaro
Thanks a lot i will try that i hope it works because my car is messed up thanks. :hail:
Old Mar 17, 2002 | 03:42 PM
Car: 1985 Camaro
it still doesnt work and i dont know why what wires should i be using and will it work its an 85 base model 305 V-8 camaro? is there any thing else you could think of i might be doing wrong?
Im sorry for asking so many questions but i just frustrated that it wont work. Thanks a lot
Old Mar 17, 2002 | 04:26 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
As far as I know it should work but I am running out of ideas ... Did anybody else test this?
Put a 10k resistor between the A and B terminals.
Connact the interface cable to terminals A and D.
Old Jun 23, 2002 | 09:31 AM
marald's Avatar
winaldl on carb computer
Tried winaldl on my 1985 Computer controlled pontiac firebird as well.
Couldn't get any data out.
I'm unable to verify the cable because there aren't a lot of american cars around here in netherlands. But as soon as I find one I'll check the cable. but for now, no serial data yet, tried the 10k resistor between terminals A & B en the check engine lights starts flashing rapidly (guess this is the 160 BAUD data stream I'm seeeing)...
I'm using Win ALDL ver. 1.07a and win95 version B (english) on a Digital Hinote 266 MHz. Com port seems to work fine, tried diffrent windows settings as wel as winaldl settings for com 1. tried with 10k and without 10k.
The firebird is an 1985 base model CC 5.0L engine code H with a standard Qjet. Errorcodes read with diagnostics are 32 & 34.. Want to know whats really wrong as replacing parts in europe can be a costly thing. (have to be flown in from america)
hope somebody can help me.
marald
Old Jun 23, 2002 | 03:22 PM
Morley's Avatar
On the '85 TPI cars pin "E" is serial data. Will look around and see if there is a diagram for the carb cars.
Old Jun 23, 2002 | 03:42 PM
Morley's Avatar
One other thought. Hook your laptop to AC power when trying to read the ECM data. I was only getting partial data till I did that.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 13, 2015 12:59 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
