350 tpi with 4 speed stick??
My car is an 86, it had a 305 tpi, with auto. The motor was week! So i had a rat 82 Z-28 with a sweet, new 350, fourspeed hurst shifter,etc...I installed everything...(pedals,clutch setup, motor, and Tpi setup, from the 305...I did use bigger injectors, and knock sensor.) what should i use for the computer chip?thanks for the help in advance.
Sanjay
Aug 12, 2015 03:41 PM
