VATS problem or no?
Old Apr 26, 2002 | 09:03 PM
MILT's Avatar
VATS problem or no?
Please hear me out.
My car ran fine. I swapped out the steering column, and now she won't start. The computer kicks out a code 53, but why would it do that when I simply reinstalled a different column? . I tried the VATS bypass anyways but it didn't work. I then had to swap out ignition cylinders b/c I lost my keys. Now VATS is definitely an issue, so I burned a chip w/o VATS and that didn't do anything either.
So, the car won't start. All accessories do work, just no fuel pump, no cranking at all. The security light comes on, but then goes out. What could I have done or NOT done? Could the neutral safety switch be involved?
I also removed the airbag, but that shouldn't do anything, right?
I'm desperate...this has been going on for over a week.
Thanks,
MILT
Old Apr 29, 2002 | 05:48 PM
mat89RS's Avatar
While swapping your sterring column did you maybe hooked and snaped a cable somewhere ? I'm saying that because a sterring column is a heavy piece and you could have done that without noticing anything ...also did you plug back the ignition connector ??? and signal connectors ??? maybe the new sterring column had a deffective relay on it ....
check that out and give us some info .
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
