1991 Firebird Formula Fog Lights!!!
I want fog lights for my car, the stock ones, does anybody have pictures of what their foglights look like on a 91 - 92 firebird.
Also where does the switch go on the dash, if u have any pictures of the switch location that would be helpful too.
What all do i need to transform my car to foglights, i maybe have factory prewired connectors if so, what do i have to do then. I have no room for the foglights on the front facia and i have no room for the switch.
Help me out!!!! please
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Here's a pic of my Trans Am with the fog lights on. The switch is the left hand most switch next to the defrost and trunk release. I don't have any pictures of that switch. There is another Formula owner that put the foglights in as well as the switch. do a search.
Foglight switch...
Okay the foglight switch is an illuminated toggle switch on the left side... (middle is my fan switch) and far right is my hatch release.
thanks alot guys for the pics.
what do you all think about my car being prewired for log lights( meaning i have connectors on each side under the car laying around the headlight area) can this be true
if this is what i have, what do i need to do to install the lights in my front nose? also i need to hook a switch up where do i hook it up to? should i have a spot on the fuse block for a fuse? should a relay also be installed since the car might be prewired for foglights?
If you didn't have foglights from the factory, you may not have the wiring going there. You can always look and see. If there isn't any wiring there, here is a good thread about wiring up the foglights with the driving lights...
Hope this helps you out.
Whoops I will find it...
Fog light hookup
Fog light hookup
i have checked my car and i actually have connectors under the front that look like connectors that are black with some kinda green color on them. Their on each side. I was trying to find out if i do have these connectors their does that mean i have everything else, other than the actual foglights/mounting hardware and the switch?? Where would the switch connect to, i want it to be just like if i had them right from the factory.
theshackle
Mar 5, 2017 06:37 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
