Is this hard?
Old Sep 11, 2000 | 08:39 AM
dtpmike's Avatar
Is this hard?
To wire a switch to pop my hatch?
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from MrMikes.com
[imghttp://img14.webshots.com/photos67/401/48/4014849WpoyzkaHvD_photo.jpg[/img]
Old Sep 11, 2000 | 08:40 AM
dtpmike's Avatar
IT is a big inconvienience o get out and pop it becasue i have to turn off my car.
Old Sep 11, 2000 | 08:46 AM
Chuck Everly's Avatar
dtpmike, I hope someone else chimes in here because I am no expert but I think you will at least need a hatch release motor and assembly. You will need the switch and I suspect that there is a relay in the line that the switch fires.
I would go to a wrecking yard and get the parts you need from a donor car.
88 IROC convertible
So slow it is timed with a sundial
Cntrvrsy's Avatar
I think there is something on that in the tech articles.
Old Sep 11, 2000 | 08:48 AM
dtpmike's Avatar
i glanced at the article, but it was for 91-92 Firebirds so i dont know if its the same. I am jsut curios if I can do it. Also why isnt my pic in my sig workign?
Old Sep 11, 2000 | 08:53 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The camaros and firebirds were available with an optional interior hatch release. Go to the junk yard and find one that has it and swipe the switch in the dash and the actuator on the motor in the trunk. You can also buy an aftermarket actuator and switch and wire it yourself, but the stock setup will be easier. Your wiring harness should already have the plugs in the center console and in the back.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 11, 2000 | 10:51 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Probably because the ubb code is turned off so no one will post stupid stuff!!
j.wolfe
________
91 GTA
KILLS
Old Sep 13, 2000 | 04:48 PM
86-red_dawg's Avatar
i did this to my 1986 camaro sport coupe
it had the power hatch before hand, and i added the switch myself - if you need anyhelp with this, i came accross quite a few solutions to get it to work -- email me at jlh8003@tntech.edu if you want and info on my installation and if you need help finding the release module
-86RedDawg
Old Sep 13, 2000 | 10:25 PM
you've got mail!
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
