Dash lighting (tach)
Old Sep 27, 2000 | 01:32 AM
jseversole's Avatar
A bulb has burned out behind my tachometer. Knowing GM, I'm sure it's a bitch to replace. Anyone ever attempted this?
By the way, it's a 1991 RS.
[This message has been edited by jseversole (edited September 26, 2000).]
Old Sep 28, 2000 | 12:15 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You will need to pull the drivers side under dash cover (by your feet), the cover below the cluster (by your knees), and the cluster trim ring, before removing the cluster to replace the light bulb at the rear of the cluster. In order to remove the cluster trim ring you will have to remove the head light switch **** / shaft assembly. Pull the switch all the way out & than press the small button on the bottom of the light switch (kind of hard to reach) & the shaft will come out with the lights still on. Pull the trim ring & put the shaft back in to turn the lights off.
Tim
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
