GM Tech/Vader/Knowledgeables Altenator Question
Old Sep 29, 2000 | 05:01 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
recently i cut the wires for my altenator...
OOPS
now i'm rewiring it and was wanting to know if this diagram looked fully functional...
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Oct 1, 2000 | 12:00 AM
Duffster's Avatar
anyone...
...anyone...
Old Oct 1, 2000 | 07:59 PM
Vader's Avatar
Duffster,
I'm still digging, but the voltmeter shouldn't be connected in series with anything. Connect it to a fuse as you have diagrammed and the negative terminal to chassis ground.
Your alternator appears to have more wires/connections than it should. What year is the alternator?
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 1, 2000 | 09:21 PM
Duffster's Avatar
1988 altenator...suprising i have something from 88 on the car
the 'B' connection is the big bolt-on cable to the battery...the other 3 are in the plug...oh....POST # 500
Old Oct 2, 2000 | 09:20 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The diagram you showed is correct, except for the following:
Move the source for the S terminal from the B wire at the alt to the large lug on the starter solenoid - add a fusible link there, too - they are available from Pep Boys. The S wire is the voltage regulator sense input & should be placed at the power distribution point.
The L terminal goes to one side of the alternator "idiot light" in the cluster (not a volt meter). The other side of the light goes to the gauges fuse (+12 volt power in crank and run).
The F terminal cannot be powered by the same set of contacts (internal to the ign switch unit) as the L terminal. It should be powered from the "hot only in run" output from the ign switch - some of the things that this output usually powers are the A/C, blower motor, & windows.
Here are the alt pin defenitions:
B = Battery
S = Sense
F = Field
L = Light
Tim
Old Oct 2, 2000 | 01:35 PM
Duffster's Avatar
NIFTY-NEATO-KEEN!!!
Does this mean the Voltmeter comes from something completly different?
I will wire as per prescribed above today and update
THANK YOU Vader and Tim
Old Oct 2, 2000 | 02:38 PM
Vader's right, the voltmeter "+" terminal goes to the gauges fuse & the voltmeter "-" terminal goes to chassis ground.
Tim
Old Jul 27, 2003 | 09:15 PM
gtabadboy's Avatar
I think my sense wire on the alternator is the problem with my car not charging. Can I just rewire the sense wire and where should I wire it to? I have a 3-wire 140amp alternator.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
