Battery harness looking fried??
Old May 21, 2002 | 07:18 PM
Ride4ME's Avatar
I changed the pickup and ignition module in my car and it started and ran fine given the timing was off. Today after it started and I moved it I went to change the timing. I didn't disconnect the neg. battery terminal and I noticed that I misplaced a couple of plug wires. So I swapped them and tried to start my car and it did. I adjusted the dissy again then the engine refused to crank at all
and all my power died ( dome light, dash, radio). The wires leading to my neg. bat terminal look fried. I don't know what caused this but If I don't get any suggestions soon I might have to sell the black beast.
And I REALLY DON'T WANT TO DO THAT,
thanx in advance,
R.
Old May 21, 2002 | 09:51 PM
NJ SPEEDER's Avatar
you can grab a neg battery cable from teh parts store and throw it on, clean the terminal out and see hwo that works.
later
tim
Old May 22, 2002 | 06:59 PM
Ride4ME's Avatar
well I got the battery cables from Autozone,
it looks like the ground extends to the starter,
so I guess this means that I need to raise the car on jackstands
to replace it right? My red cable was hooked to the positive side is this correct?
Old Jun 1, 2002 | 03:23 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Ummm, no? The ground (black -) heavy wire connects to the block near the alternator, and the small pigtail connects to the body next to the battery. The positive (can be either red or black +) heavy wire connects to the starter, with the pigtail running to a junction block which connects to the charging connection on the alt, another wire to the fan(s), and yet another wire to the ??? (ECM I believe).
Old Jun 7, 2002 | 11:01 AM
adclass's Avatar
Car: 92' RS
Engine: 305 TBI
Transmission: 5 spd
Check all the wires some of them have fusible links somewhere along there path going to the starter and to the alternator they burn up like a fuse also check the ecm/ fuel pump fuse if you have one most of the time it should be right next to the battery in a small fuse holder if that happened your dash lights should be all strange.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
customblackbird
Oct 1, 2015 04:30 PM
Johnoooooo
Sep 22, 2015 08:55 AM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
64goatman
Sep 9, 2015 01:09 PM
