Trunk will not pull down
Old Oct 12, 2000 | 10:40 PM
Sandman's Avatar
After I installed a new stereo and new speakers in my car my trunk stoped pulling down. I put a new motor in it worked for about 10 minutes and stoped working completely. I sent it down to my mechanic and he could not get it to work either. Can anyone help me???
Old Oct 12, 2000 | 11:34 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
more of the symptoms please...
Old Oct 13, 2000 | 05:31 PM
irocz_ca's Avatar
don't know whether you got that trunk that closes electrically with a little push or not. if you do, maybe you just have to find the right alignment for the mechanism to work. mine once in a while moves down and won't close until i have to realign the mechanism. loosen up the bolts and move the mechanism and tighten them up. keep trying till the trunk closes. and if it did, then you solve the problem. well, anyway, that it the first thing that i would do first before going to more expensive solutions.
Old Oct 13, 2000 | 05:48 PM
Duffster's Avatar
Well Irocz, he did say "trunk stoped pulling down. I put a new motor in..."
so that would give us a big clue there.
Just waiting to hear the symptoms of it if any and noises...and such...
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Holley 80457,600cfm w/vacuum secondaries,84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Oct 13, 2000 | 06:57 PM
Stuart Moss's Avatar
I had an intermittant problem with mine that turned out to be the connector that attaches to the motor making poor contact with the pins. I removed the wires from the connector and expanded the sockets to it'd make better contact and have not had any problems since.
That said, you can easily check it by moving the plastic switch in the latch when the motor has moved it to the "up" position. When the hatch closes, it moves this switch to tell the motor to pull the assembly down. Just move this switch with your finger and see if you can get the motor to operate. Wiggle the wiring and connectors, especially to the motor to see if you can get to operate.
If you get it to go down, simple releasing the switch will tell the motor to move the assembly up.
Just curious, why did you install a new motor?
You did check the fuse, right? (Sometimes the most obvious is the most overlooked...)
Old Oct 13, 2000 | 08:14 PM
camaro 22's Avatar
mine motor sometimes goes down with out the trunk going down with it with out me knowing. expecially when i use my key to open it. in this case the trunk doesn't wanna shut. all i do, is with your finger, there is a like a switch on the motor wich you can get to without taking anything off or apart. it's where the trunk thing catches to. just push down on it, and it'll bring the motor back up to the top again, and now the lid will close. this is for me at least. good luck
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Glowsock
Sep 5, 2015 07:48 PM
