Tach acting up
Old Oct 15, 2000 | 08:46 PM
Zeplin1073's Avatar
Tach acting up
I have a 91 RS and for the past few months it has been sitting.I drive it every so often but it sat for about three weeks before I could drive it again. My problem is the tach goes red line in normal driving and it gets buried when i step on the gas. If anyone can help I could use it. This does not give me any codes or effect the performance, it just bugs me out if I want to drive.
Old Oct 15, 2000 | 09:13 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
sounds silly, but i'm guessing the needle has done a 180 on you and you might try pulling the face off, and flipping it back down.
sometimes under extreme acceleration...or when in park/neutral and gassed HARD, the armature of the needle could flip and now it's happy 180 out...
Old Oct 15, 2000 | 09:34 PM
Zeplin1073's Avatar
I dont know if that is the prob. When I am sitting at a light the idle is normal, then as I step on the gas it goes up normal then it jumps up higher.What I would like to know if the tach is elextrical or if at any point it is vacum and there could be a prob. Also I have seen some other people talking about a "tach filter"? would this be my prob????
Old Oct 16, 2000 | 08:34 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The tach is completely electrical, and there were no tach filters used in '91. Sounds like the tach itself has a problem. Check the connection & condition of the white wire that goes to the harness from the coil - it routes to the tach input.
Tim
Old Oct 16, 2000 | 08:36 AM
One more question - if your RS has a V6, what are the yellow & red lines on the tach?
Tim
Old Oct 16, 2000 | 11:57 AM
Zeplin1073's Avatar
I have a 305 V8. I dont know what those wire go to. I will check the connection and the wires, thanks foe the suggestion.
Old Oct 18, 2000 | 06:45 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Here's my 2 cents on this. You could have another electrical problem, causing your tach needle to bounce around. My aftermarket tach in my S15 truck was bouncing around alot, intermitantly. I thought maybe I had a miss in the engine under light acceleration. I found out that I had a bad plug wire. I think it came loose from the plug, then started arcing/coroding in the boot. Since the tach pickup is connected to the coil primary, the arcing was reflected back from the secondary(plug wire). I replaced the wire and problem solved.
Just thought I would pass this along.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Oct 18, 2000 | 08:45 PM
Zeplin1073's Avatar
Thanks to all for your help. The problem was with the servo that controls the tach gauge. It had gone bad so I replaced it with a another and problem solved.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
