windshield wipers won't work with new moter
Old Nov 7, 2000 | 02:07 PM
black305power's Avatar
my wipers won't work even with new motor and the wires are so burned i can't tell where they go and my book doesn't have a wire diagram is their a way to test my wire to find out where they go
Old Nov 9, 2000 | 06:50 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Do you have delay wipers or hi / low only wipres? What year?
Tim
Old Nov 9, 2000 | 12:34 PM
i have a delay wipers but the wire are burned to the point that i can't see were they went.
Old Nov 10, 2000 | 07:05 AM
The pink wire goes to terminal D (variable voltage, depending on delay control position, power in mist position, off position, and power when washer is engaged). The dark green wire goes to terminal C (power in low speed position, mist position, and off position). The gray wire goes to terminal B (power in mist position, high position, delay position, and when washer is engaged. Terminal A goes to terminal B of the motor connector. Purple goes to terminal A of the motor connector (power in high position).
What year is your third gen??
Tim
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
slade5612
Aug 11, 2015 07:19 PM
