Electric problem
Old Nov 10, 2000 | 10:02 AM
Floppysj's Avatar
Electric problem
I'm not getting any power to my car 89 (pontiac GTA).Car would not start, no light,radio,nothing.The only thing that is working is the dome lights when u open the car.I figured it would have to do something with my starter.I check under my car and there is a black wire right above the starter and right below the headers,does anyone know whatis it?
Old Nov 11, 2000 | 01:04 AM
turbo497's Avatar
did u check ignition & saftey nutural switch
Old Nov 11, 2000 | 07:54 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The problem may be your starter solenoid. that has the neutral/clutch safety switch in it.
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Old Nov 12, 2000 | 10:38 PM
Topgun's Avatar
Sounds like a battery problem. Like it is drained and only has enough power to run the dome lights, try the head lights at night and see how bright they are, if dim, it's the battery, if bright, another problem
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
180º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's KFC-6906S
New Pioneer Sub TS-W253C
New Jensen 4-Channel Amp XA-4150
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Nov 14, 2000 | 08:41 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The starter solenoid does not have the neutral safety or clutch start switch located in it. The NSS is located in the console, connected to the shifter mechanism, and the clutch start switch is located behind the clutch pedal lever.
Sounds like an ignition switch or ignition switch feed problem. There are three fusible links connected to the large lug on the starter solenoid. One feeds power to the ignition switch (and some accessories), & the other two are for the exterior lights (and some other accessories) & the alternator sense input.
Tim
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
