Wiring problem.
Old Nov 9, 2000 | 11:36 PM
Ggarso's Avatar
Wiring problem.
I have a 1990 Formula 350 I do not know if this is stock or if the original owner did this. I have a wire coming of the battery that supplies power to the fans, when the primary fan comes on like it should and I am stuck in traffic it melts the fuse holder on the wire and then after a few days it blows the fuse. Is my fan drawing to much current and going bad? I am at a total loss here.
Thanks, Gary
1990 Formula 350
Old Nov 10, 2000 | 07:29 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The factory setup uses a fusible link - a short small gauge wire - that feeds a large gauge wire that routes to the fan relay(s). A fan motor draws around 8 to 10 amperes, or so. If it is drawing more than that, the motor is probably on its way out. Pep Boys sells lifetime warranty replacement fan motors for around $50, or so.
Tim
Old Nov 10, 2000 | 12:45 PM
Ggarso's Avatar
Thanks Tim, any particular fusible link size, like 30 Amp
Thanks, Gary
1990 Formula 350
Old Nov 14, 2000 | 07:46 AM
I've seen 14 ga & 16 ga fusible links. If I remember right, the 16 ga link package had GM marked on it. I'm not sure what the amperage rating of the links are.
Tim
Old Nov 14, 2000 | 08:45 PM
Ggarso's Avatar
Thanks, I went ahead and ordered a new cable. I think the fusible link should be part of it.
Later, Gary
GTAman
Mar 15, 2019 11:40 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
Bert87
Aug 23, 2015 03:50 PM
g.l.mos
Aug 22, 2015 12:02 AM
