Battery keeps dieing...
Old Nov 19, 2000 | 02:56 PM
Camaros4_life's Avatar
I bought this car and a later on noticed that the battery is not recharging, so my first thought is that the altinator is bad or the voltage regulater on the altanator is not correct, so I am going to pull it off and take it to auto store and have it tested, The reasone I am posting is because I am wondering if anyone has had this problem and what they did to fix it... Is there any other things that could cause this? (Bad ground, somthing internaly is on when it shouldn't be. ect.) Any help would be cool... Thanks for you time.
Old Nov 20, 2000 | 04:42 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
You should check your B+ wire that connects the Alternator to the + terminal of the starter. This wire is sometimes damaged by heat and does not conduct electricity.
William
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
