Longer starter cable
I want to run a longer (+) cable from battery to starter, over the fenderwell and back down under the A/C box to reduce heat soak from the header. Will I experience any problems using a longer wire? The cable is the same gauge thickness with excellent connections. Resistance will be more with a longer wire though right? Do I need to go up to a 4 gauge ground and hot cable? 6 is stock right?
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Not sure what the stock size is, but it won't hurt to go with a larger cable; also you may consider installing a Ford remote starter relay in-line with the cable...it will definitely help the heat-soak problem.
Pete
Pete's Place
HiOutput Virtual Racing Team
Pete
Pete's Place
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You cannot go too big, run as big a cable as you can afford. I run a "00" gauge(1/2") cable on both positive and neg because I have 10.5:1 compression and a hi-torque starter.
You will have less voltage drop with a large cable which keeps full battery voltage to the starter. Makes cranking quicker especially in cold weather.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
86 Camaro Sport
wigmobile
Feb 26, 2025 02:56 PM
