keyless installation
Old Dec 24, 2000 | 03:35 PM
Keith5's Avatar
Car: C1500
I want Keyless Entry for my bird, but I don't want to have to do a lot of modificatoins to do it.
I want to be able to take it out and it be like it was never there. Is there a lot of wire cutting involved? Can this be gotten around if so?
I also would like a remote start too, but I figure there is a lot of modification involved with that, exspecial with VATS.
Any input will be appreciated.
1985 Camaro IROC-Z LB9
1989 Pontiac Firebird
Formula W6S LO3 TBI 305
-180 degree stat
-Hooker Cat-Back
Old Dec 25, 2000 | 01:06 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
You can install a keyless entry without cutting any wires except for your two lock/unlock wires.The rest can just be spliced into with t-taps,though I recommend stripping back a portion of the insulation and soldering the connections.That's the way I do all my installs.Much more reliable in the ever vibrating enviroment of an automobile.Your lock and unlock wires must be cut because the relays must be wired in between the switch side and motor side of those wires since our cars have a reverse polarity system for the power locks. Even with remote start,everything can be put back together without anyone ever knowing there was anything there,if it is done correctly.
Old Dec 25, 2000 | 02:27 PM
Keith5's Avatar
Car: C1500
That's good news, when I get the system I'll get one that has remote start too.
Old Jan 15, 2005 | 11:17 AM
Slow2.8's Avatar
WHat color are those two wires? The lock/unlock?
Old Jan 15, 2005 | 01:02 PM
Keith5's Avatar
Car: C1500
I can't remember the colors of the wires, I actually installed a keyless entry system, but not the remote start as I put said I was going to back in 2000, lol.
I took the door panel off and traced which wire was which from the switch. I already had to take the door panel off anyway because I had to fix the lock on the passenger side.
Old Jan 15, 2005 | 03:16 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Not a single wire had to be cut including my lock/unlock wires when I installed my remote.
Old Jan 15, 2005 | 04:06 PM
Keith5's Avatar
Car: C1500
I didn't cut any either. I used those little plastic snap things that tap into a wire without cuttting them.
Old Jan 16, 2005 | 11:26 PM
Chilo's Avatar
Car: 91 Z28
Engine: 355 TPI
Transmission: Streetfighter 700r4
www.bulldogsecurity.com
Everything you nee to know about any car in order to install auto alarms, including remote starts. Use at you own risk.
Old Jan 17, 2005 | 09:06 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Just remember - the remote start can only be done on a automatic car since you pretty much have to park a manual tranny car in gear...
Old Jan 17, 2005 | 01:13 PM
Keith5's Avatar
Car: C1500
People do it sometimes anyway though. Just have to make sure that you leave it out of gear if you plan on starting it remotely the next time. And they also bypass the clutch cutoff switch.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
