check engine light...please help
Old Dec 27, 2000 | 02:54 PM
B84305-Streetmachine's Avatar
whenever i come to a stop light......after sitting for a minuite or two the check engine light lights up.....whenever the light turns green and i get it up to about 20-25 it goes back off...and it does this while idling for a while sometimes.. anyone know what this is?
Old Dec 27, 2000 | 03:39 PM
84TransAm's Avatar
go to any Auto Parts store, get a GM code Scanner (82-96) and stick that in your Assembly Line Diagnostic Thingy. It is below the dash (described in booklet that comes with it). It costs like $30 or so, and can be used to Diagnose any check engine light. The alternative is to go to a mechanic and have them use the same tool, and charge u $75 or thereabouts. It is so easy to use and diagnose, that AOL seems much much meaner than that.
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock emissions restricted slow 150 hp(chilton rating) 240 torquer that needs RELEASE!!!!
Old Dec 28, 2000 | 12:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A free solution is described here: http://www.racer-x.f2s.com/proc/codes.htm
Once you know what the code is, then you figure out how to fix it!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
