speedometer hookup
Old Dec 28, 2000 | 08:33 AM
Josh Crose's Avatar
speedometer hookup
I need help to hook up my factory electronic speedometer. It's an '86 Trans Am. I removed the original carbureted wiring harness which had the plugs to connect the speedometer. I've tried to hook it up, but with out any luck. Do i still need the buffer box? please help.
Old Dec 28, 2000 | 12:21 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You will need the VSS buffer. The VSS on the transmission feeds the VSS buffer, and the VSS buffer drives the speedo in the cluster, and the cruise control module - if you have cruise control.
Tim
Old Dec 28, 2000 | 01:39 PM
Josh Crose's Avatar
Thanks for your response. I tried to hook up the VSS buffer already, but nothing happened. I do not have cruise control. What else should I try?
Old Dec 30, 2000 | 07:02 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
http://www.angelfire.com/mt/psh/speedo.htm
Pete
Pete's Place
HiOutput Virtual Racing Team
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
