GMTECH-PLEASE READ!
Old Dec 28, 2000 | 01:19 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
GMTECH-PLEASE READ!
Hopefully you have dealt with this problem before. My 89 iroc tpi fails to restart sometimes. Does not matter if it is hot or cold. If you wait about 5-10 min. it will start with no drivability problems. I know it is not the VATS,injector leak down. Could I be experiencing a fuel pump/relay problem? My car has done this for years and I just can't deal with it anymore. You know the FORD guys "that f@#$%& chevy won't start at the tree again!
Old Dec 28, 2000 | 06:20 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
When you say it fails to start, will it spin over or not crank at all?
If it will spin over, the possibilities are endless. The best way to find out is to start checking for things when it acts up. Does it have fuel pressure? Spark? Injector pulse? Its very hard to diagnose when it starts up fine, so you will have to wait untill it won't start, and start investigating.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 28, 2000 | 06:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Carry some starting fluid with you and the next time it doesn't start spray it in the throttle body and try starting, chances are it will fire right up and will run normally.
The ignition module will cause this problem.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans, Jamex Springs.
http://www.sethirdgen.org/octride.htm
[This message has been edited by John Millican (edited December 28, 2000).]
Old Dec 29, 2000 | 05:58 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sounds like you have experienced this before or something?!?!?! Whats up, John?
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Dec 29, 2000 | 10:45 AM
Engine: 4.0L
GMTech,
I still have not changed my ignition module yet, it hasn't acted up in a month now since it's been real cold. Knock on wood....
I'm waiting on front end parts right now before I go to the track. I heard they're closing Savannah Dragway soon.
John
86 Camaro Sport
Old Dec 29, 2000 | 05:16 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Where did you hear that from? I didn't think it was that public. The lady who I guess owns it says the land has been sold. To bad they couldn't just dig everything up and plant it in my back yard!
I guess it will be L&L in Hinesville (eeek!) after this year.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Dec 29, 2000 | 07:53 PM
Engine: 4.0L
I know the owner, he works at my work as a mechanic.
86 Camaro Sport
Old Dec 29, 2000 | 10:38 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
I hate it when I hear good strips biting the dust. America needs places like these to let the kids race somewhere, and NOT on the roads. oh well what are you gonna do eh
Old Dec 30, 2000 | 05:23 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
John-
The starter fluid worked! What makes you think it is the ignition module? Isn't this fuel related?
Old Dec 30, 2000 | 06:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
John and I have discussed this for quite some time now. The ignition module controls the ignition timing when the RPMs are less then 400 RPM (cranking speed) known as "bypass mode". The ignition module also passes along the pulses from the pickup coil to the ECM for injector control. We have agreed that for some reason, while the ignition module is in "bypass mode" the pickup coil's pulses are never being sent, hence the "no start". But when you spray the starting fluid and the vehicle actually makes it past 400 RPMs, the Ignition Module switches to EST (computer constrolled timing) and lets the pulses go to the ECM and then fires the injectors. Johns car is doing this, but we havn't actually put a module in yet to prove it, but we really think thats it.
South East Thirdgen
Savannah, GA
'87 Trans Am
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Dec 30, 2000 | 06:25 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
For what's its worth. Starting fluid (ether) is really tough on the valves/seats as you can tell by the way the engine sounds when you crank it over and you think its coming apart. Try holding the front throttle plate open and spaying WD-40 into the intake. WD-40 lights up in everything from 2-stroke weed eaters to the 350 in my wife's Olds 98 with no clattering noises.
Z's r Best
Old Dec 31, 2000 | 11:29 AM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
O.K. This is starting to make sense.Could having my timing too far advanced also cause the no start? I don't think the timing is off because the car just passed smog test hear in Ca. with my zz4.Anyone know how I can get my picture in the members rides section?
Old Dec 31, 2000 | 01:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If it was your timing to far advanced, then it would fail to start every time. Not now and then, not after five minutes, but all the time. Put a module in it and let us know if it does it again.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
