85mph V6 Cluster to 145 mph V8 cluster
Old Jan 6, 2001 | 02:39 PM
Mike Harvey's Avatar
Well the Subject line pretty much says it all. Will this work in my car easily without any problems. I have an '86 Firebird w/ the 85mph cluster & want to swap to a '91 T/A 145mph cluster.
Can this be done w/ no problems? Thanx
- Mike Harvey -
1986 Firebird S/E
Old Jan 6, 2001 | 08:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not exactly. The atachs are different: the V6 motor gives 3 pulses per revolution of the crank, but the V8 gives 4; so if you put a V8 tach in a V6 car, it will read 3/4 of the right RPM.
You should however be able to put your 6-cyl tach in the other cluster, and then everything should work.
Old Jan 7, 2001 | 09:08 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
RB is exactly right, the TACHs are different.
But the speedo's are basicly the same, providing your car has a VSS. If the speed sensor in the back of your trans has two wires, your OK, If it has the big black speedo cable, your going to have problems.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 11, 2001 | 11:35 PM
Ovrclck350's Avatar
Hey Mike. Since you're doing the KITT conversion, why don't you go w/ the KITT dash too? I found a site somewhere where the guy makes em, AND all the useless plastic overhead and console pieces COMPLETE w/ the usless buttons and switches that will light up. Would be kinda cool to hook Nitrous up to a SUPER BOOST button or somethin.....although since KITT was a v6, doubt the 6'er could handle it easily
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
GTAwheelman
Feb 14, 2008 07:37 PM
5SPD Hero
May 16, 2007 01:38 PM
GeforceXtreme
Jun 4, 2005 07:41 PM
zee28
Sep 16, 2002 03:33 PM
RED82TA5.7L
Nov 29, 2000 08:01 PM
