Wiring Diagram for stock 92 Z Fog Light Switch?
Old Jan 9, 2001 | 11:33 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I just got a 92 Fog light switch for my new foglights....i didnt like the cheesy red switch that came with them....first of all...how do i mount it to the dash? The stock one is huge...and has a bracket riveted to the switch and 2 screw holes...what do i do with that? Also....there are 4 connectors on the back.....what do i connect them to? Thanks for the help.
http://users.ticnet.com/mult68
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Pretty good sound system
More to come.
Old Jan 11, 2001 | 09:45 PM
mult68's Avatar
Engine: 305 TBI
Anyone know?
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
More to come.
Old Jan 12, 2001 | 10:02 AM
jm91rs's Avatar
I did the same thing with my car,...the stock switch looks much better. will see what i have written down and get back to you on the wiring
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows
Old Jan 12, 2001 | 10:19 AM
mult68's Avatar
Engine: 305 TBI
Ok thanks...so where and how did you end up mounting the switch?
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
More to come.
Old Jan 12, 2001 | 12:00 PM
jm91rs's Avatar
the switch is made to go under the headlight ****. If you have a camaro, there should be a little panel under there that just pops out. The switch mounts in there. You could cut that cover to fit your switch or just go to chevy and pay like 3 bucks for one that is made for a z. That's what i did. As far as the actual mounting, it is easy if you take that trimplate (the one containing the cigarette lighter and defroster and headlight ****) off the car. On the back of that should be the holes that the switch can get screwed into. That trim plate is the same as the one that z's come with. Just find some screws that fit in there and it should mount up great. Pop the new cover on there, wire it up and you are done. As far as wiring, from the notes i have, it looks like the switch is set up as follows. ( i will do my best to describe it. the letters represent the prongs on the switch)
A
--B
D C
or similar.
-The A prong gets grounded to something in the car.
-The B prong gets run to a power wire (if you want the lights to be on only when the car is on, just wire that to the fuse block)
-The C prong gets run to the foglights
-The D prong is run to an interior light so the switch lights up when your lights are on.
hopefully this is clear, let me know if you need anymore help
[This message has been edited by jm91rs (edited January 12, 2001).]
Old Jan 12, 2001 | 12:03 PM
jm91rs's Avatar
the "A" prong would actually be positioned above the "D" prong at the top of the switch
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
Brcharrelson
Aug 26, 2015 07:47 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
