Audible Turn Signals
Old Jan 19, 2001 | 09:08 AM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
Does anyone know of a gizmo that beeps or chimes loudly with the turn signals? Too often I catch myself running down the road with a blinker on. With a loud dinger, this would never happen.
'87 IROC 5.7l TPI - original owner!
Old Jan 19, 2001 | 10:35 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Radio Shack sells small 12 volt piezzo audible alarms that would work. You could either use two alarms - one for each turn signal, or use two 1N4003 diodes (from Radio Shack) and one alarm. For the one alarm / two diode setup, connect the cathodes (banded ends) of both diodes together & connect them to the positive input of the alarm. Ground the negative input of the alarm. Connect the anode of one diode to the left turn signal wire (light blue wire coming out of the steering column), and connect the anode of the other diode to the right turn signal wire (dark blue wire coming out of the steering column). The alarm will beep when the turn signal bulbs illuminate.
Tim
Old Jan 19, 2001 | 12:00 PM
Jza's Avatar
Jza
Also, some auto parts places sell what are called "loud" blinker relays. (Just like that with the quotes). They just click loudly to remind you they're on.
Old Jan 22, 2001 | 12:25 AM
Chris Luongo's Avatar
Yeah, J.C. Whitney sells loud turn signal flashers.
Personally, I can't stand that cheap-sounding clicking...I've been trying to find a silent one. I once tried wrapping the flasher in duct tape, but it didn't make much difference.
Old Jan 23, 2001 | 12:46 PM
P J Moran's Avatar
Engine: 5.7l TPI
Axle/Gears: 3:23?
Tim,
I couldn't find any ready-made "kits", so I went to Radio Shack. I used the "one buzzer, two diodes" approach. It only cost me a coupla bucks, givertake. It worked like a chime!(typo intended) Thanks for the suggestion.
Old Jan 23, 2001 | 05:40 PM
mech's Avatar
Yeah. I think they sell some that zap the driver if they're on for more than 10 seconds. Ask AutoZone or some other auto parts store if they have them.
Old Jan 25, 2001 | 10:16 AM
Jza's Avatar
Jza
Just on a side note, I think cars should come with exploding blinker relays so that when old people or idiots on cell phones leave them on after a turn it'll explode after maybe 35 blinks.
Old Jan 29, 2001 | 03:01 PM
evilho7810's Avatar
My 90 cutlass had a warning beep if your drove with your turn signals on for more than a block.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
