Need to know how to "install" starter wires
Old Feb 3, 2001 | 09:52 AM
Mike86Z28's Avatar
Car: 98 Z28
I am going to buy a wiring harness and wondered how hard it is going to be to get the stater wires in. My old wires were cut by an a****** lazy mechanic and now I need to get my car running again. So is there a plugin around the firewall or somewhere or am I going to look at sodering the wires?
Old Feb 4, 2001 | 12:33 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Your best bet is to solder the wires & use either heat shrink tubing, or electrical tape to insulate the solder connections. Don't forget that the 2 or 3 car power feeds that connect to the large lug on the starter use fusible links - if those were cut off, they should be replaced as well (available from Pep Boys), since they are the only fuse protection for some circuits.
Tim
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
