Torque Converter Lockup switch
Old Jun 18, 2002 | 08:37 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey I have removed my computer and all of the electronic junk. I did leave the Computer harness in tact. Is there any way to wire a toggle switch up to the harness to lock the converter in 4th gear. I have seen the ALDL way but it can not be used now.
Thanks for the advice.
Brian Felts
Old Jun 19, 2002 | 01:37 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I'm doing this Thursday, I let you know what I do, if nobody else helps you out between now and then.
Old Jun 19, 2002 | 12:31 PM
FatOne's Avatar
Guy I have the same problem. Looked around for awhile at aftermarket toggles. Well there are kinda expensive. Found an article in Car Craft place named Auto Rite. Makes a pressure switch that will lock up after you hit fourth gear. They sell the kit for $62. With the article seems very easy to install into tranny. And best of all no toggle on/off all the time. You can reach them at www.auto-rite.com
Old Jun 19, 2002 | 02:01 PM
ATOMonkey's Avatar
You SHOULD just be able to find the 12V wire on the back of the trans that controls TC lockup and take that to ground with a switch. I did the ALDL thing personally, but it's been without such things.
I don't know for sure. Let us know how it turns out.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
