Can someone help me to install manual fan switches?
Old Feb 17, 2001 | 02:44 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm trying to set up my fans so that I can turn them on at any temperature. My cr is overheating while sitting in traffic and I was wanting to have a switch for each fan so that I could stop this. Could someone please tell me how to do it?
Thanks for the time
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods due in March:
K&Ns
RAM Air
Air foil
AFPR
Hoping to get a couple of tenths with that lot
Old Feb 17, 2001 | 08:53 AM
Stuart Moss's Avatar
This topic has been discussed in detail in the past few months. I would suggest doing a search (try "fan switch", "fan", etc. in the "electronics" section).
All the information you asked for (and then some!) should be covered in the many posts that have been made.
There is also an excellent article about doing this in the "Technical Article" secton on the home page.
Old Feb 17, 2001 | 08:35 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I just converted to an electric fan and I put in a manual switch. The temp sensor for the fan grounds itself when it reaches the temp range it was designed for. When this happens the fan comes on until the engine cools down and the fan turns off when it reaches the low temp. So all you need to do is wire a toggle switch in parallel with the sending unit. Ground one side of the switch and connect the other side to where the sending unit connects. Hope this info helps, good luck.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
fasteddi
Sep 2, 2015 10:29 AM
TA8487
Aug 16, 2015 12:21 PM
dhonda200
Aug 11, 2015 11:50 PM
