Gas gage wrong!
Old Feb 19, 2001 | 06:57 PM
Viking's Avatar
Car: / 89 IROC /
Gas gage wrong!
Maybe the past 6 mos or so I've noticed that my gas gage is giving incorrect readings when it comes down to the last few gallons. By setting the trip OD I know that I have lets say 50 more miles before empty but the gage would read rock bottom, pull over now EMPTY. Look again in 10 minutes and it reads 1/4 tank! Even when full it rarely gives a correct reading, always fluctuating greatly. I replaced the gage but same result. Is there a fix or is this just the way it is?
89 IROC original owner, 3 amplifier 8 speaker Kenwood/Infinity sound system, 300,000 miles on original 305 TPI. Change your oil!!!
Jeff's IROC Restoration
Old Feb 19, 2001 | 07:51 PM
Biochem's Avatar
Car: 2002 SOM z28
My old gauge and my new one both read way over full when the tank is full. When it gets to about half full... the gauge suddenly drops to 1/2 and then reads normally until E. I think it is my sender... you may have crud on your wires. They work on resistance.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Feb 20, 2001 | 09:22 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Do you stop quickly? I have a 1988 Firebird 305 and when I stop at a light the gas gage will drop by a quarter to an eigth depending upon the stopping speed. Try stopping slowly and taking corners slowly. If the problem still occures I don't know what to tell you. About everyone I have asked about this has the same problem. It is a Firebird thing, maybe a Pontiac thing.
Old Feb 20, 2001 | 09:24 PM
TZFBird's Avatar
Engine: 327
Sorry maybe it's a 3rd gen thing. I didn't see what car you drove. Sorry about that Viking.
Old Feb 21, 2001 | 12:03 PM
cfabe's Avatar
Gas gauges are the most inaccurate guage in a car. In all my cars, even my new s-10 with what should be an accurate gauge, I usually decide when to fill up more based on the trip odometer then on the gas gauge. More then half of the cars I've had in the past few years have had inaccurate or broken gas gauges. So my opinion is just live with the problem, dont bother trying to fix it, because even in like new condition it is not going to be an accurate, linear, fullscale representation of how much gas you have left.
Old Feb 22, 2001 | 09:22 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I have to agree with the previous reply, the fuel gauge is very inaccurate. Mine will go about 50 miles before it breaks the full mark after refueling. Then it just swings all over the place. After setting overnight it goes up a little.
My advice, just use it as a reference only, and as recommended by some, don't let your tank drop below 1/4 otherwise you run the risk of sucking up some sediment from the bottom of the tank. It also keeps moisture from condensing inside the tank.
Old Jun 17, 2007 | 01:56 PM
chrisnflicker's Avatar
Car: 2002 Camaro
Engine: V6
Re: Gas gage wrong!
My gas gage stays below empty even if its a full tank, there is power to it because when I turn it on it moves a little bit. I can't figure out whats wrong with it!
Old Jun 17, 2007 | 05:49 PM
Viking's Avatar
Car: / 89 IROC /
Re: Gas gage wrong!
Holy old post, might be a record for a resurrected thread.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Dyno Don
Jan 24, 2016 08:24 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
Ian Irvine
Sep 4, 2015 08:08 AM
