HOW do I get rid of top speed limiter????????
I have an '89 RS Camaro with a 305 TBI. I just purchased a Stage 2 jet performance chip. And I thought that would get rid of my top speed limiter. But it didnt. My car stops accelerating in 3rd gear at 4,000 rpms. Is there any way to get rid of this so I can hit top speeds?
I have an '89 RS camaro
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Check out the PROM board. You can use TunerCat software and a PROM programmer to recalibrate the speed limiter set in the PROM. A cruder method would be to install a switch in the VSS wire to the ECM and open the switch when you want to exceed the speed limiter set point.
Tim
Tim
<font face="Verdana, Arial" size="2">Originally posted by Tim Burgess:
Tim</font>
Tim</font>
I dont have any prom recalibrater tools. Would I be able to have a shop do this kind of work? Where could I get these tools?
Car: 04 GTO
Transmission: M12 T56
OR, you could get funky with the cheese whiz and use a double throw switch on the VSS wire to the ECM. Once side as stock, and on the other one, oh, i don't know, maybe a divide by 2 counter. Then you wouldn't even throw a code, but you could return to stock for stuff like normal TCC lock-up points, etc. You see, an absolute cut off will throw a code pretty soon. As a WAG, i don't think the ECM would notice a divide by 2 counter as long as you didn't use it extensively during slow commuting.
You know, i may build this tonight. I absolutely hate driving up the highway with freaks trying to race me, only i can't cuz my vert has a 105 limiter on it.
then again, maybe not, i promised i'd stop frankensteining this car and just start burning proms for it.
...ed
ps...If you wanna get really trick you could add some logic and a clocked counter to automatically engage this. Of course if you were getting that deep into designing stuff, you could also build a 5/8 divider that would automatically switch on at the same time for the speedo, so your kph would now be your mph.
Or even better, maybe *I* should start building these devices and selling them for low cost. I wonder how much interest i could get for that. Hmmm, i've given away the whole design in this post, but i'm sure there are enough people around here who wouldn't know how to apply it anyway...and for a small fee, why not pay me to build it. But that then gets me back on the road to designing a line of digital guages in custom enclosures....damnit, i have too many ideas.
...ed
IF you want... I'll re-burn your JET chip for you and remove the 110 mph top speed limiter. Email me..
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
92 Z28 5.7
Check out Truspeed
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
hey Blade those are some sweet pics. I noticed your white face gauges. Those are awesome where did u get them? Also once I get my limiter removed I want to install the 145 MPH speedo as well. Where would I go to get one of those and how hard would it be to install and recallibrate. What Blade has is what I have been looking for!!!!!!!!Check out his links to his picks
Hey, Ed, I designed that for my '84 Berlinetta with a digital dash - it normally flashes @ 85 mph, so the circuit engages KPH above 84 mph & scales the pulse train such that the readout is in MPH. Above 135 mph, it reverts back to MPH & divides the pulse train by two & reads MPH/2.
Tim
Tim
Tim</font>
Tim</font>
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
