Starter soloniod
Old Feb 21, 2001 | 02:56 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Starter soloniod
One day I went to start my car, The starter spun, slow, and would not stop. Even when I turned off the key. It just spun 'till the battery died. It even spun when I cut the starter wire under the dash. I remember in school, the teacher talking about the soloniod getting stuck. Does anyone know what I'm going through?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 21, 2001 | 08:19 AM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
It sounds like a bad solenoid. It could also be a mechanical binding in the starter, but more than likely it is just the solenoid. You can replace just the solenoid (which doesn't cost much), or you can replace the whole starter to be certain.
If it was me, I would replace the solenoid.
Old Feb 22, 2001 | 01:52 PM
stingerssx's Avatar
I'm going to be dumping the worn 200 for a WC T-5 and a new 350 soon. I just need to get the car turned around.
Old Feb 22, 2001 | 05:20 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
A manual trans setup requires a different starter than an automatic trans setup, so you will be purchasing a new starter when you do the swap, as well.
Tim
Old Feb 23, 2001 | 06:18 PM
Flywheels with two different diameters are used on small block V8's and 90º/V6's. Large flywheels/flexplates are 14" in diameter and have 168 teeth, small flywheels/flexplates are 12¾" diameter and have 153 teeth. Most blocks are drilled for both types of starters. Large diameter starters have two offset bolt holes, small diameter starters have two bolt holes which are parallel to the back of the block. Unless you are changing the flywheel/flexplate diameter, the starter will fit.
[This message has been edited by TunedPort350 (edited February 23, 2001).]
Old Feb 24, 2001 | 11:08 PM
stingerssx's Avatar
Yeah Tim, I found that out, but my T/A is at my grandmothers house, and I would like to turn it around to drop the motor in, and it's on a small hill. Just big enough so that I can't push it. Also, tuesday I go in for back surgery, and I'll have to wait to do anything anyway.
Old Feb 25, 2001 | 12:45 PM
The ODB's Avatar
don't you have big strong friends?
or how strong is your granny?
I'd push any day before changing starters.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
