Help Me Please, I Am Pulling My Hair Out!!!!
Old Jun 27, 2002 | 06:53 PM
kevosiroc's Avatar
NEED HELP FROM COMPUTOR GURU!!!
OK, here is the deal with my 1992 B4C 5L 5 speed. My engine is running at high idle, sometimes bounces from 2000-2500 rpm. I have checked/ replaced map sensor, IAC, TPS, EGR and evap canister--still have problem. When I check the engine wih my Tech 2 tool, I have 0 position on the IAC, but when I hit the throttle, the IAC moves. It sounds like a vacuum leak problem, but I cannot find the leak(I have been searching for it for a long time). The only places left to check are the intake manifold to head gasket and injector O-rings. Someone said once that an injector could be out of balance, but I cannot check for that. I know that the engine has been replaced because it is painted orange and some of the electrical connecters were broken
PLEASE HELP, PLEASE!!!!!
Old Jun 28, 2002 | 02:50 PM
howardhughes's Avatar
does sound like a vacuum leak,simply spray a flammable penetrating oil all around the gasket areas and the injector seals. to get o iac counts usually the leak will be close to the iac valve.also check the throttle plate and clean any black build up that my be in there.keep a fire ext.handy for safety reasons.good luck
wigmobile
Feb 26, 2025 02:56 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
