Poorly fixed VATs system...
Old Mar 7, 2001 | 09:57 PM
EO273KiD's Avatar
Ok, I recently found out that someone else has tried to fix my VATS system on my car. The security light periodicly stays on after putting the key in and sometimes i have to try a few times while allowing it to reset itself. I followed the orange wires that run from the ignition cylinder to find they were cut and taped off. There is about a 24" piece hanging from the steering colum. Where does this wire usually run? I think the previous owner may have wired a resistor in line. Does this orange wire stay orange the entire way to whereever it goes, (computer?), or does it change to another wire i should look for. Where is the computer even located, ohh man, i got real problems..
Owner of a 1989 IROC-Z Camaro, a.k.a. "The Babe Magnet". Painted a cheap metallic blue that chips off all too easily and covers over the IROC-Z decals on the doors, also has non-leaking T-tops, ps, pw, power rear hatch, working A/C. Mods: SLP intake runners, gutted MAF sensor, adjustable fuel pressure regulator, modified air spoil, 3.27 posi rear end.
Broken stuff: rear spoiler brake light, driver side lock, power antenna, tilt steering, rear end bushings, cracked passanger side ground effect, washer fluid tab, leaking exhaust and a rotted through muffler that sparks when the car bottoms out while driving like any 17 year old does.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
gta892000
Aug 11, 2019 11:16 AM
R13_Braz
Sep 18, 2015 05:00 PM
Winchester1094
Sep 15, 2015 09:48 AM
