HELP!!! FOG LIGHTS WILL NOT TURN OFF!!!
Old Mar 9, 2001 | 01:01 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
My fog lights will not shut off. The parking lights are off and so is the switch for the fog lights, but the fog lights remain on. The parking lights are off. WTF is going on here. I also disconnected the fog light switch thinking that it burnt out keeping them on but the lights are still on. Please help me quickly, the battery is slowly dying!!
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 9, 2001 | 01:42 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Try removing the fog lamp relay. It's located on the driver side engine compartment. It's attached to the fender close to the window. If this doesn't work just remove the bulbs!
85 305tpi Tans am
flowmaster exaust
K&N air filter, 4:11 rear gears
Old Mar 9, 2001 | 07:23 PM
I figured it out, it was a relay that is mounted in front of the washer bottle that shorted out.
Old Mar 9, 2001 | 07:25 PM
I figured it out, thanks. It was the fog lamp relay that is mounted in front of the washer bottle. I replaced it, it works fine now. It was shorted out.
jaridjohn
Jul 8, 2024 03:49 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
