cruise will not engage at all....this is what i tried so far.,
Old Mar 11, 2001 | 08:03 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i checked the fuse, i checked all the vacume hoses and connections i put in a new vacume actuator,but it just seem that there is no juice in the whole system :O( were do i begin to diagnose the switch???in the colum... orcould it be the the cruise cont. module(where is it what does it look like) it wont work at all i had another 89 TA and i swapped out everyhting but the cullom stalk switch, i think i swapped out the module but i wasnt sure where or what it looked like..man where do i start i justknow it is in the electrical system and not vacume or mechanical can u shed some light?
THANKYOU!!!
Old Mar 11, 2001 | 08:08 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
START with the multifunction lever!
they are cheaper than most of the parts youre talkin about and they are usually the first to go.
Old Mar 11, 2001 | 08:34 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
u must mean the steering collom mounted switch on the stalk..... thanks
any one else
Old Mar 12, 2001 | 01:57 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
actually I mean the whole stalk thing.
what most people call "the blinker stick"
to replace it is kind of a bi**h but they are really cheap from pick your part or you can just go to a parts store and pick one up for like 50$
then the fun part is getting the Cruise control wire down through the steering coulmn. I messed it up so now I just run it along side and it doesnt look that bad.
Old Mar 12, 2001 | 04:04 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
by the way i got a complete steering collum and ignition key out of another 89 TA....( and i know the switch in this one is good) but when i tried to install it.. the car wouldnt start. i think the vats in collum#2 isnt compatable with the original... how could i get the #2collum to work with the car? ...is there a way to test the switch with the collum out of the car with a multimeter or sumthin?? if i could just swap out the while whole collum that i know works then i can move on to the next thing.... thanks
later ed
Elephantismo
Feb 13, 2019 12:51 AM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
