No power?!?!?! HELP!?!?!?!
Old Mar 25, 2001 | 01:09 PM
Doug E's Avatar
I put a new starter in this morning, and when I put the car down to test it, I had no power, none. No lights, radio, fans wont turn on, etc, etc. Its like my car has no battery. Does anybody have any idea why or what happened? I suspect a fusible link, but can't seem to locate the one coming off the starter. I also checked the battery, and it is fully charged, and its connected.
Any one have any ideas??
Old Mar 25, 2001 | 02:46 PM
RS'er's Avatar
Your positive battery cable isnt hooked up to your starter,or theres a blown inline fuse somewhere around the starter.
Old Mar 26, 2001 | 12:20 PM
Doug E's Avatar
TTT
Old Mar 26, 2001 | 07:19 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
I think I know this one.....Your fusible links, if they're anything like the ones in my car, ARE the wires going to the large terminal on your starter. If you open the tape-wrapping on those wires, you'll see a black plastic block about 10" up on each of those 2 wires-this is the other end of the fusible link. Replacements for these have to be spliced onto the cable, and it is a PITA considering their location.
DR Stevens
Car #1: my ride
1984 TransAm
305HO(L69) 96K & counting
750 cfm Q-Jet/Holley rem.
K&N filter
700R4/Superior shift-kit
and trans cooler
3.42 rear/3.73 blew up!!
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel/'84 ram air
3" exhaust of some sort
partial emissions delete
Car #2: My wife's ride
1991 Firebird/Formula
305TBI(LO3) 99K & smoking
K&N air filter
Hypertech Chip
more engine mods later
"Hey, Uncle Sam!! Where's my f**king tax return??!!"
Old Mar 26, 2001 | 08:01 PM
Doug E's Avatar
I found the problem,
On the black cable that hooks up to the main terminal on the starter, I believe there is the ignition wire. I took the starter apart this morning, and that wire was barely hanging on, so I wired a new connection for it and my car started right up. All power was returned, and it runs good. Thanks for the help everyone!!
Old Mar 26, 2001 | 08:40 PM
RS'er's Avatar
Knew it Same thing happened to me a few days ago,I was quite worried when it happened to me
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
