Proform shift light
Old Jul 7, 2002 | 05:08 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Proform shift light
I am thinking of purchasing proform adujustable shift light, and was wondering about the wiring of it. I know it is going to require me to hook it up to the tach wire on my distributor. I want to retain my stock tach and this light at the same time; so can I run my stock tach wire and the shift light wire together into my distributor? Will both still run correctly? It is possible to have this hooked up and my stock tach hooked up at the same time isnt it?
Here are some links:
http://www.proformparts.com/parts/67005C.html
http://www.jegs.com/cgi-bin/ncommerc...72&prmenbr=361
Brady
1992 Camaro with holley carb and accel HEI distributor
Old Jul 8, 2002 | 02:05 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Both should work OK when connected to the tach line. You can tie into the white wire going to the tach in the cluster to control the shift light. Attached is a cluster pinout list.
File Type: zip
Old Jul 8, 2002 | 09:03 PM
thank you very much!
Dialed_In
Aug 20, 2015 01:45 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
