Remote Starter/Vats problem
Old Apr 2, 2001 | 06:28 PM
Ovrclck350's Avatar
OK, I was reading in the manual for my Remote Starter and it listed a way to bypass VATS by wrapping wire around a spare key and the lock cylinder or something where that it would only bypass the VATS when you used the remote starter. Could someone explain this to me and possibly give me an easier way? It's the only problem i expect I'll have w/ the remote starter/keyless entry system.
Old Apr 2, 2001 | 08:54 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Your alarm should have came with 15 resistors. One will match the key ohms. This gets wired in under the dash. But this also disables VATS 100% of the time.
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
Check the rest out here
Old Apr 2, 2001 | 10:53 PM
Ovrclck350's Avatar
this is what it says...complet w/ typos.
Old Apr 3, 2001 | 09:55 AM
JPrevost's Avatar
Car: 91 Red Sled
So what is VATS is disabled! It's been around too long and just about everybody knows how to bypass it with basic electronic knowledge. Even drug rehab rejects usually know about the single piece of electronics (can't post the actual name because many think it'll help theaves) that can bypass VATS. If you're installing a remote starter why not go with something like the avital avistart 6500 which comes with a starter disabler. It saved my car even though the VATS was disabled.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 3, 2001 | 10:12 PM
Ovrclck350's Avatar
I would still like to do it the right way though, and not completely disable it.
Old Apr 4, 2001 | 11:17 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
You have to use a relay to temporarily bypass the VATS while the engine is being cranked by the remote starter.This will disable the system only when it recieves a signal from the remote start unit for the car to be started.E-mail if you would like wiring info.
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
ASCD SS hood, High-rise Z-28 spoiler
Flowmaster cat-back,gutted cat,Iroc sway bars,wonderbar,140 Iroc gauge cluster,Iroc steering box,open air filter,AFPR
TBI mods
383 stroker in April!
President-Austin 3rd Gen F-body c.c.
Austin 3rd Gen F-body c.c. message board at www.hpsmotorsports.net
Also, www.ride4life.net
[This message has been edited by RSpeed (edited April 04, 2001).]
pjsparts
Oct 29, 2025 06:39 PM
tglennon11
Sep 23, 2015 05:30 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
