Arching plugs
Old Apr 9, 2001 | 12:32 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Arching plugs
Here is the problem. On two spark plugs there are sparks jumping from between the boot and the insulation to the metal on the plug.
I have an MSD6, MSD GM coil, Holley Annihillator 9mm spiral wound wires, and Bosch Platinum plugs. I used the silicone grease that came with the wires, the wires and boots are OK, and no sparks anywhere else.
The question is what can be done to keep the spark from jumping out of the boot. The boots fit very snug around the plugs too.
Any ideas?
Old Apr 9, 2001 | 07:12 PM
TopForm's Avatar
You could have gotten too much dielectric grease on the plug and the spark is just taking the least path of resistance (through the grease to the metal on the plug). Or there may be small cracks in the boots that the spark is getting through. I would check all the boots again and remove some of the grease. Another thing could be a cracked spark plug.
Hope this helps some,
Brian
Old Apr 9, 2001 | 08:58 PM
NitroMac's Avatar
the spark from the coil is a very high voltage and if needed it will take the path o fleast resistance even if it means right through your plug boots. i agree with TopForm make sure there is not an excess of the grease on the plugs or boots. to check if the plugs are cracked i would swap plugs with a different cylinder and see if it still happens. if yes wipe off the grease.
you can never have too much horsepower
Old Apr 10, 2001 | 06:11 AM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Well the plugs are brand new and so are the wires, and they checked out good. I had Rapidfire plugs on it before and one of them was cracked and the sparks were a lot worse. I will clean off some of the excess grease and see what happens.
[This message has been edited by Ozzy88GTA (edited April 10, 2001).]
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
