Frustrated with alarm system....
Old Apr 13, 2001 | 05:36 PM
JPrevost's Avatar
Car: 91 Red Sled
I have an avital avistart 6500 (remote starter and alarm, the works). I bought a pager system a while back and tried installing it last week. The darn thing sets off the alarm. I think I must have hooked up a wire wrong but could it also be that maybe the pager is actually setting the alarm off through voltage drop? I wanted to hook up my 2 way mirowave sensor but I can't figure the dual shock sensor out for the life of me. It's all about voltage DROP and the sensor I bought is all about sending a signal, not taking it away. I thought about a relay but then the relay is going to draw power when the car is off. I think I'm at a loss. Anybody have any ideas?
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 15, 2001 | 10:36 PM
chrisfrerick's Avatar
did you share the same power line from alarm with the pager? because if you did i know that the 4 watt pager when it goes off can draw the voltage down and it would trip the alarm. have a dedicated 12v line for your pager.
Old Apr 16, 2001 | 12:40 PM
bruhaba's Avatar
diode isolate the sensor from the alarm
Old Apr 17, 2001 | 03:48 AM
JPrevost's Avatar
Car: 91 Red Sled
Sounds like a plan, thanks guys. What would I do without thirdgen.org and it's members....??!!!
  • 8" harm. balancer
  • Alston SFCs
gta892000
Aug 11, 2019 11:16 AM
1992Z28!
Nov 19, 2015 07:33 AM
RedLeader289
Sep 23, 2015 06:50 AM
Stauf
Aug 24, 2015 08:31 PM
