What is the best place to pick up a power lead under the dash?
Old Apr 15, 2001 | 12:42 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I need to install a couple more guages and I need to pick up some power inside the car under the dash
all my the wiring harneses a nice and tucked away and all wraped up .....I dont want to start riping into them all to find power
I was thinking of trying the cd player power ..I can get to that easily
Can anyone tell me the best place to grab power???
thanks
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Apr 16, 2001 | 06:23 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Use the gauges fuse (pink / black wire).
Tim
Old Apr 17, 2001 | 09:35 PM
tpsierra's Avatar
Your fuse box has sockets for GM single wire plugs that can be on always, switched, acc, etc, go to the junk yard, look at fuse blocks especially of caddys and buicks. they unplug by pressing in tab. depending on where key on side is, depends on where it can plug in, but you can slice off the key and use in any socket. Red plugs work in always on sockets, for example.
Vintageracer
Jan 10, 2020 05:33 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Brcharrelson
Aug 26, 2015 07:47 PM
stalkier
Aug 13, 2015 12:59 PM
