my horn has a mind of it's own
Old May 9, 2001 | 07:58 PM
knightjacob's Avatar
hey, I need help with my horn. Today at school it was just chilling in the parking lot and the horn started going off. For now I just want to disable it, but I don't know where to do that?? But what are the possile problems???
Old May 10, 2001 | 08:54 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
This happened to me last year. i was in my house and the horn just started to go off.after i got it to shut off the horn stopped wroking. anyway is it still going off? if the horn died it is probably that the horn is shot or there is a bad wire that conncets to the horn button. that was the problems with mine anyway.
86 Z28:
350 vette
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
Old May 10, 2001 | 09:14 AM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I had a similar problem on my '89 RS. When I'd go around a corner sometimes it would go off. The piece that you actually press to make the horn work was loose. It would slide and the contacts would hit, as if you were pressing the horn. I just pulled that part off, and bent the contacts wider. I had to do this every so often, once I'd start beeping while I was driving, I'd take it off, then the next chance I got, bend the contacts again. Good luck.
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd B&M Ripper shifter, hopefully I can rob a bank or something and get more
www.geocities.com/irocnroll90
Old May 10, 2001 | 10:20 AM
gmanuel's Avatar
Also check the horn relay. Mine had a contact inside the relay that was deformed. I was able to open the relay and rebend the contact.
Old Aug 8, 2010 | 05:41 PM
masterp_17us's Avatar
Re: my horn has a mind of it's own
I am having the same problem on my 84 z28.Pissing me off. Some pictures or a parts diagram would help greatly...
Old Aug 8, 2010 | 10:33 PM
If anyone could supply a parts number for the horn switch assembly on an 84 Z28 that would be awesome. If not I'll start my own thread here in a day or two...
grngryoutmyway
Oct 18, 2016 05:48 PM
Veaceonee
Sep 29, 2016 08:15 PM
tmellott89
Oct 14, 2015 02:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
