park/neutral switch rewiring on 700r4 to T5
Old May 11, 2001 | 09:05 AM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
Here the deal:
I have a 86 firebird that had a 700r4 and I'm am now changing it to the T5. I am working on the switch rewiring. in my repair book it shows in the wiring diagram with the ignition wires (purple/yellow pair) split with a { going to the two different switches the one labeled M/T and one A/T. Next to the M/T it shows the clutch start switch and by the A/T it shows the park/neutral start switch with the purple/yellow pair going in to it. The is an other Park/neutral switch for that is connected to the ECM but there is not a corresponding Clutch start switch that goes to the ECM. Any way my question is: does the ECM park switch need to be connected into the clutch switch? Maybe that ECM switch has something to do with the TCC and I won’t even need it, I don’t know. Does any body have any idea what to do?
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Old May 13, 2001 | 01:48 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
With my bird all I did run two wires from the park/neutral switch conectior in the console to the clutch switch on the pedals, it will give you the same (push in the clutch to start the car action) as a normal manual car.
89 T-Top GTA 350 5-speed (soon to be 6-speed)
(Jet hot coated)1 3/4 SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,free mods.
G-Tech times
0-60 5.2s
E.T. 13.91@104.8MPH (2300ft)
Old May 14, 2001 | 03:08 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The wire to the ECM is grounded in P or N, and as far as I know, tells the ECM to increase the RPM in P or N. So, if you are installing a T5, you would probably want to leave it disconnected & the idle will be fixed at 600 rpm, or so.
Tim
Old May 14, 2001 | 04:11 PM
Car: 1989 Firebird
Engine: 2.8
<font face="Verdana, Arial" size="2">Originally posted by Tim Burgess:
Tim
</font>
increase the RPMs when in P/N or when out of P/N
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Old May 15, 2001 | 03:03 AM
Tony89GTA's Avatar
Car: 89 GTA
To tell you the truth my car idles fine with the clutch in or out. Just make sure you let it idle down when you first start the car and before you move, or when you let off the gas it will stay at a higher RPM and it wont idle down properly until you let it sit. Between(1800-1200)rpm
G-Tech times
0-60 5.2s
Old May 15, 2001 | 03:05 PM
As indicated above, RPM increases in P or N with the switch closed (ECM wire grounded).
Tim
Old May 15, 2001 | 03:14 PM
Car: 1989 Firebird
Engine: 2.8
Thanks all!!
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Old May 16, 2001 | 03:53 AM
Tony89GTA's Avatar
Car: 89 GTA
After you do what I said your car will operate like a normal manual car with no idle problems and it will idle down properly, just to let you know.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
