Anybody here running a Hypertech Fan Switch?
Old May 11, 2001 | 04:24 PM
George Khawahie's Avatar
Car: 1988 Camaro IROC-Z 'Vert
I'm looking to use this switch in my 88 IROC and wanted people's opionions. My main question is the difference... Did you guys see a difference in how the temperature of the car was after installing the switch? Thanks!
Old May 11, 2001 | 11:01 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Well, i'm not running a Hypertech, but i've got a Jet fan switch. It's really one of the best things I ever did for my engine, keeps it right in the 185-200 range. I've also got a hi-flowing water pump and a 180 stat. I'll have an aluminum radiator once I put the new engine in.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
Old May 12, 2001 | 01:17 AM
Was there a notciable difference in gas mileage?
3rdgen.org - Real Cars, Real People, Real Fast!
Old May 12, 2001 | 08:13 PM
Anybody?
Old May 12, 2001 | 09:58 PM
Car: 84 T/A
Engine: 305HOL69
In my case not really, but i'm driving around a place where it's nothing but stop-go stop-go stop-go, so my mileage is always lousy, no two ways about it. I put it in so that my engine wasn't always running in the 220-240 range, I was concerned about roasting gaskets & stuff. The last time I checked my mileage on the highway I got about 20-23mpg, original '84 L69 engine with a new carb and Accel ignition and a bunch of other stuff. I'd say i'm getting around 12-15 in the city.
DR Stevens
Old May 13, 2001 | 08:32 PM
NitroMac's Avatar
cooling down the engine may not change your gass mileage at all. it may lower the temp of the intake possibly causing a lower incomming air temp and better combustion, but maybe not.let me know
you can never have too much horsepower
Old May 15, 2001 | 05:12 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Along with a lower temp T-stat, the Hypertech 176-166 Switch was one of the first things I changed in my cooling system. The temperature used to rise at a normal rate all the way to past 220, but after installing the switch it took a little bit longer to get there but sometimes depending on traffic it would stop before 200. The switch did make somewhat of a difference but did not cure the high temperarutes inherent with third gen cars.
If you want to stay below 200 all the time you are going to have to do a lot more than just replacing the fan switch.
Old May 16, 2001 | 09:08 AM
RyanSS's Avatar
I had one of those on my last car, a 92 RS. It along with a hypertech stage2 chip, and 180 degree stat kept it below 200 almost all the time. BTW i live in west texas and it gets very hot here.
89 RS (supposed 350) TBI auto
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
86IROC112
Aug 17, 2015 02:00 PM
