Third brake light
Old May 3, 2001 | 12:21 PM
prepz28's Avatar
Third brake light
third brake light doesnt work on a '86 IROC. all the bulbs are new and everything looks fine. any ideas???
Old May 3, 2001 | 02:27 PM
89RustangRemover's Avatar
i don't know if your rear hatch is like my 89er. but next to the pull down motor, there is a box with metal contacts in it. it's got like 4 silver contacts. then, on the hatch itself theres the connector box with 2 prongs sticking out that sits on the deck when closed. if u press the brake with the hatch open, it wont light because it doesn't have power. so, i recommend that you check the contacts (might have to pull the panel out) check the wires, connections, etc. also, it wouldn't hurt to check all the fuses.
"WARNING: Objects in mirror are about to disappear VERY quickly!"
Old May 3, 2001 | 02:37 PM
prepz28's Avatar
thanks, i've actually checked all that and it all seems fine. i've checked everything (well obviously not everything) im gonna give it another try but could there be something else im missing?
Old May 3, 2001 | 05:26 PM
Tonyrodz's Avatar
Transmission: auto
I had the same problem w/mine, someone cut the pwr lead to the contact. Check that too.
I spliced into a brake light wire, so when I stepped on the brake the 3rd light worked.
Make sure you don't splice into the blinker wire. This is a 2 person job.
Old May 3, 2001 | 09:49 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I had the same problem on my 86 Sport Coupe. Also try shifting around the light assembly. I had to wedge something thin under it at the end near the roof. Seems it wasnt making contact with the grid in the glass.
Old May 3, 2001 | 09:51 PM
Vader's Avatar
Prep,
Also check the two connections at the rear hatch strut lower ends. These can get pulled off easily. The connection between the foils on the glass and the lamp housing itself are not all that impressive, either.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old May 8, 2001 | 12:32 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I had the same problem with my '88. I had to bend a few of the bulb's metal leads out a ltiile to make proper contact in the socket. They have worked fine ever since.
Also, please read my post about third tail lights. Any help appreciated..
Ed Miller
Charlotte, NC
1991 RS, 305 TBI,
bone stock driver;
1988 IROC L98
TPIS Fast Pack, modified MAF, MSD 6A, Dynomax cat-back so far.
"Do you want to race or don't ya? I want to race." Dale Earnhardt
Old May 14, 2001 | 10:32 PM
87ColdAirIroc-Z's Avatar
I don't know if your contact is made through 3 metal prongs pushed onto 3 metal plates when your hatch is closed. Mine is like that. All i did to fix mine was to clean those metal plates with steel wool.
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
Old May 15, 2001 | 07:51 AM
prepz28's Avatar
actually it's only 2 metal prongs..
Old May 15, 2001 | 10:24 PM
StormFX's Avatar
Myn has a crack in the housing causing the contacts not to touch. I need to get a new housing.
350 TPI
300 HP
Flowmaster Exhuast
Hood etc.. coming soon
Old May 16, 2001 | 09:37 PM
CAMARORS1991's Avatar
Like the previous guy said about the crack in the housing, I had the same problem. Check this to make sure the sun hasn't cracked it over time. I had to use superglue and a clamp to get the housing to hold together again and then the brake light worked fine.
Old May 20, 2001 | 01:25 PM
87rustybluebird's Avatar
in my 87 someone didn't like the third light so thay cut the wire right where it comes out of the brake switch on the pedal arm
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
