How to wire these Autometer gauges
Old May 20, 2001 | 06:14 PM
CAMARORS1991's Avatar
I know very little when it comes to wiring up things in my car so here is my question. I bought an Autometer trans. temp and air/fuel ratio gauge. On both of them it says to wire it to ignition switch. Im assuming this would be the wires on my ignition cylinder. If so which one?? Also for the trans. temp gauge I have to wire the light to come on when I turn my headlights on, so would I connect it to the wire on the back of my headlight switch, and again which one?? Thanks for any help.
Old May 21, 2001 | 11:33 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
I actually wired mine to the switched wire on my radio.
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 23, 2001 | 01:29 AM
89GTA5spd's Avatar
It is a snap to hook up autometer guages to thirdgens (at least it was in mine). The fuse box under the steering wheel has power outlets labeled ignition and guages, battery, and maybe a few others. Just buy an electrical connector that is flat and attatch it to one end of the wire and plug it into the corresponding slot. Since you don't want your guages on until you turn your ignition to on, then tap into the slot labeled ignition. All you need after that is a ground and the wire from your sender (or in mechanical guages tubing from source). The lights on the guages even dim with your stock dimmer when you hook the bulb 12 volts to the guages terminal.
Old May 25, 2001 | 09:17 PM
Thanks for the help. Wish I knew that before I did it my way. I hooked it up through the radio like the previous guy suggested. It works so I guess I did it right. Thanks again.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
