305 to 350 TPI computer questions?
Old May 26, 2001 | 12:56 PM
JucinGTA's Avatar
have a 305 TPI set up with a 9th injector, im gonna put a computer from a 350 TPI without the 9th injector setup will that be ok?
Old May 27, 2001 | 02:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, its fine, but you should disconnect the 9th injector so you dont flood the engine on startup. You are swapping to the 89 MAF computer?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 27, 2001 | 06:03 AM
IROC KID's Avatar
I have an 86 305tpi,i was wondering if there would be any benefit for me to swap the computer and which one would i put in?
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
Old Jun 3, 2001 | 10:11 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Iroc Kid, I do not believe you need to replace your ecm (if you want to remain with MAF), but converting to the 89 eprom (ARAP is the best MAF version) and disabling the cold start injector is all that would be needed to do this.
You may also want to consider going SD. Check out the DIY PROM Board and do some reading. There are plenty of posts on this subject. Also, Grumpy (Bruce Plecan) just did an post "MAF vs SD...no BS" that lists the differences between them. There are times when you may wish to consider going with SD. But for most 305 guys, there is no need. But converting to an 89-type setup is the best way for MAF guys to go.
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
