Stock Distributor with MSD6 AL??
Old Jun 9, 2001 | 08:53 PM
NOCANDO's Avatar
Help...Ive been reading that in order to use the MSD6AL, you'd have to replace the distributor's bushing because the resistance is too high that it would cause the distributor to melt. It is true, or can I use the stock distributor with no problems. Also, how is the MSD Blaster Coil, stock number MSD-8226. Is it worth replacing the stock with it....thanks.
Old Jun 10, 2001 | 02:51 AM
Z_Ghost's Avatar
I have the msd 6al and blaster coil on my 92Z.
I put it on in February and am using the stock distributor, no problems. Dose the blaster coil help, a little bit, it idles smother than it did before I put it on, the stock coil had about 130,000 miles on it.
92 Z/28
Hotchkis springs,LCA,panhard rod, tie rod sleves,STB
Bilstein shocks,struts
AGR steering box,pump. Wonder bar
Simmons Wheels 17x9.5 275x40x17 FZ50
K&N air filters, airfoil. Alum drive shaft,MSD6AL,coil
Ported Plenum ,Ploshed inside runners,intake ports, Gutted air box
60' 1.937 (4-20-02)ran a 13.953
1/8 8.839 (2-11-01)
1/4 13.851 (2-11-01)
mph 98.16 (2-11-01)
Old Jun 10, 2001 | 03:43 AM
NOCANDO's Avatar
Thanks for the reply....will give it a try. Do I have to increase the gap in the plugs too?
Old Jun 10, 2001 | 03:48 AM
Z_Ghost's Avatar
You do not have to, I run my pluge with a .038 gap.
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
