check engine light doesn't work
Old Jun 12, 2001 | 03:08 PM
BlackZee's Avatar
The "check engine light" does not come on during startup or when jumping the A-B connectors. I cannot access trouble codes. What could be the problem? I going to check the bulb to see if it is burned out.
Old Jun 12, 2001 | 04:48 PM
90Form350's Avatar
You need to jump the terminals, then turn the key to run (but dont start the car). It will flash "12" a few times, then start flashing the codes.
Old Jun 13, 2001 | 10:10 AM
BlackZee's Avatar
That is what I have been doing, but it doesn't flash at all.
Old Jun 13, 2001 | 12:53 PM
RGZWS6's Avatar
B U L B
Old Jun 13, 2001 | 06:17 PM
JPrevost's Avatar
Car: 91 Red Sled
Check the bulb. If it turns on when you go to turn on the car then it isn't bulb (duh) so check the back of the aldl. Sometimes the wires have been cut etc.
, Jon (350 TBI!)
91 Red My website
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
