VATS module
Old Jun 26, 2001 | 04:48 PM
kryptotonics's Avatar
VATS module
Are all VATS modules the same if not whats the diferance. I need one for an 89'Iroc motor what should I get? thanx
Old Jun 26, 2001 | 11:57 PM
colincamaro's Avatar
They are very different. Each one is programmed for one of 15 different key resistance levels. If you get a new one it has to be programmed & from what I've heard you can't reprogram a used one.are you installing the motor in a different car & do you have the original module, If not your best of buying a new one and getting it programmed then you will have to buy the matching key. Hope this helps
Old Jun 27, 2001 | 01:59 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
A new module will program itself to whatever resistor it sees on it's first power up. A used module must see the resistance code that it was programmed for to operate, and may not be changed.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Jun 27, 2001 | 02:32 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Tim's right, they come blank, and learn the key's value upon power-up. GM won't take them back once installed.
When I bought one several years ago (before all of the .com & Dal etc), they were about $150.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
