Car alarm.. stock ??
Old Jun 27, 2001 | 01:22 PM
NHcamaro's Avatar
I'm saving up to buy a car alarm...but I'd like to be able to fix the one in my car. I'm not sure if its stock I mean could it be stock ? Heres whats wrong with it. (that i can tell) some1 cut the ground to the siren itself, inside the car on the shock sensor the ground is cut too and I'm sure there are other things missing. The remote is light green with 2 dark green buttons and one small yellowish green button any idea if this is stock or what brand it could be? I'm thinking its not worth dicking with and i should just get a whole new setup
Old Jun 28, 2001 | 10:36 PM
Chris Luongo's Avatar
If you can just hook those cut wires back up, and the alarm works, go ahead and use it. But otherwise, as you said, it would be far less expensive to just go ahead and buy a new one.
And that definitely is an aftermarket alarm...no thirdgen had a factory one that I know of. '88-up cars have the VATS security system, but it only keeps the car from starting...no siren, or remote, or keyless entry.
Old Jun 29, 2001 | 11:34 AM
NHcamaro's Avatar
So does my car have VATS? How does that work ?
Old Jun 30, 2001 | 01:16 AM
Gen X Maro's Avatar
The VATS system uses a resistor in your ignition key to send a certain amount of ohms to the starter...if the correct ohms are not sent the car will not start...
Old Jul 1, 2001 | 09:35 AM
Is your car '88 or newer? Look at your ignition key...the VATS chip looks very odd and you will spot it right away, if you have one.
If you have VATS, then good...it can and does help make your car harder to steal. If you don't have it, forget about it. There are people on the Internet who are trying to retrofit the system into older GM cars, but it would take a lot of work and money.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
Exxon Limited
Aug 9, 2015 08:13 PM
mustangman65_79
Aug 8, 2015 01:18 AM
